razdrvr said:Anyone tried these housings?
http://www.driftnamiperformance.com/Headlight_Conversion_p/sdt-lhp7x6.htm
crazyjim said:
MG2000XJ said:Thats the same kit I will eventually order, but my question is with the ballasts and bi xenon hi/lo's do you still need/should upgrade the harness?
PurpleCherokee said:I got em in and I LOVE em! Took about two hours start to finish, the H4 bulbs fit like a glove and they're BRIGHTAbsolutely NO regrets here. As long as they hold up they'll be dollar for dollar the best upgrade yet for my jeep.
Describe what happens when you switch on your brights? Different bulb?besthaticouldo said:i used an e-code housing and 5000k conversion.
they are by far the best lighting solution. they are bright, but not blinding. they are aimed correctly, a bit down then i would have my halogens, however they are still farrrrrrrrrrrr brighter then the halogens. its not even comparable. they are perfect.
