kelly klassen
- British Columbia
What size wheel are you running, 15x8 or 15x10? What backspacing? This would be with 33x12.50s. Thanks.
kelly klassen said:What size wheel are you running, 15x8 or 15x10? What backspacing? This would be with 33x12.50s. Thanks.
kelly klassen said:So no one is using 10"!? Every book at each shop I've gone to has said 15x10 for 33s. I'm not scared of runnig slightly undersized wheels, I think I'd prefer to. The problem I've found with 10" is the backspacing. 4" seems to be the norm. I've even seen some at 3.63". That's a lot of unsprung weight hanging out there. Somehow, I don't think our little unit bearings would be up to it. I've got around 5" right now, and TJ flares ready to go on. I don't think I'll have a problem with clearance, so I would like to keep them in as much as possible. Thanks for all the help.
wetmuskrat said:33x10.50, 15x8 rims, 4in. backspacing
TOZOVR said:33x13.5 LTBs....15x8 on 4" of BS
Perfect with the BW's
