I have a 99 XJ that has developed some gremlins, the airbag light comes on and either the tach and speedo drop to zero, or all of the guages drop to zero. The problem only lasts for approx 3 minutes and then everything is fine. No other problems while this is going on, runs normal etc.....
Checked it out on a snap on scanner, code comes up as M.I.C. not responding. ( mechanical intrument cluster not responding ) and no other codes.
Thanks for any info
Jp
Thanks for any info
Jp
