[email protected]
What is a good back up light to mount on roof racks? I was thinking about the hella 550 fog. any info would be great. thanks
Handlebars said:![]()
All I need is that one Hella work lamp. It has 2- 55 watt fog lamp bulbs, it's bright and throws a broad beam... perfect for a back up lamp. Just don't try running extra back up lamps off of the existing wiring, put in a seperate fuse and relay in to supply the power. I got all of that at Susquehhana Motorsports.
'Cause you will get major voltage drop in your wiring that way. The easiest way to get bright lights is to give them full battery voltage.JLane99XJ said:why not just patch into the existing wiring, i've burned mine off the existing wiring for about a yr. w/ no problems not even the 1st blown fuse & alot of times when i'm needing extra light thrown rearward @ camp or in the shop i'll burn em for how ever long i need em, just turn the key to run & pop shifter into R... ??
