going from 4.5 to 6" need some info??
well now that its in you should realy measure, you want the output shaft and pinion to be parallel. i would say if the shaft looks like its angled pretty good, which it probably is, (mine was) go wit the four.
if you installed the lift then you should have no problem installing these, pretty much put them underneeth the leaves (fat part in the back) and run the centering pin straight through the whole thats already there.
WELL THEN DONT LOOK. GO TO A DIFFERENT THREAD. I NEEDED ANSWERS AND THERE IS SOME GOOD PEOPLE ON HERE THAT WERE ABLE TO HELP. BUT YOU ALWAYS HAVE THAT ONE CRETARD THAT HAS TO SHOW HOW BIG OF AN A## HE IS. WELL THAT PERSON IS YOU ON THIS THREAD......:shocked: :explosion
want a
