Sponge Bob
Attitude Racing
- Mokena,ILL
i found one. i think you could use the driver side one to get the exhaust over the trans to the pass side and use the stock pass side.
Sponge Bob said:i found one. i think you could use the driver side one to get the exhaust over the trans to the pass side and use the stock pass side.
Root Moose said:Am I being silly to worry about the heat from the transverse pipe going into the bellhousing and the back of the heads? Sure you can heat shield but...
Someone may have mentioned already but what about making some manifolds? Then you'd get exactly what you want.
xjbubba said:The exhaust fit problem is critical. If no one else has direct experience fitting the 5.3 into an XJ, you're going to be the man!
My advise is to either build a mock-up of the block, similar to what I did, or drop your block into place and see what's needed.
I hung my engine by my hoist, and laid up fiberglass over all critical areas, including exhaust ports, engine mount surface, bell housing and oil pan. I reinforced this shell so it would hold the weight of the stock manifolds. Installed this "kludge" into my XJ, and went from there.
It becomes painfully apparent where the cutting needs to begin.
Honestly, if I had to do it over again--assuming I wanted a Ca SMOG legal job, I'd cut out the front frame rails and build a new set out of 3/16-2X4 tubing, grafted into the stock rails, starting just aft of the LCA mounts--you'll want those gone anyway. This way, the rails can be lower than the manifolds, and give more room in the bell-housing area as well.
DO IT!!! be enovative and ground breaking, we dont advance out XJ knowledge and experence base if we dont go there!! :lecture:DrSockMonkey said:These recent posts have been eye opening for me. I have a 6.2l diesel/700r4/np231 drivetrain waiting to go in. And I am quickly coming to the conclusion that I may need to go to a different platform to use my drivetrain. I don't think trying to stuff it into the XJ is going to be worth it. Sorry for the hijack...![]()
Why not?DrSockMonkey said:These recent posts have been eye opening for me. I have a 6.2l diesel/700r4/np231 drivetrain waiting to go in. And I am quickly coming to the conclusion that I may need to go to a different platform to use my drivetrain. I don't think trying to stuff it into the XJ is going to be worth it. Sorry for the hijack...![]()
OK, OK, It has been done, and I am being a big baby...Root Moose said:Why not?
There was one for sale on ebay a few months ago so it certainly can be done.
DrSockMonkey said:OK, OK, It has been done, and I am being a big baby...
