87xjco
- Denver, CO
Gears/Lockers/LS? I've got options
I've got several different options available for HP30, D35 and other housings
Option 1:
A Tru-track with 4.56 Yukon gears currently in a disco housing, used 1 season. They will fit any HP30 housing and the Tru-track will work in LP30 housings also.
(I'll install in your housing with a new master kit for $450.00 includes parts and labor, you can be there as it's being done if you like)
Option 2:
(Or if you want the HP30 disco housing with a cable operated disconnect, installed $450.00 includes parts and labor)
Option 3:
I also have brand new 4.56 Yukon thick gears and master kit that fits any HP30 with 3.73 gears or numerically lower carrier.
(so if you only want 4.56 gears with no traction adder, I'll install in your housing for $350.00 includes parts and labor)
Option 4:
If you need to re-gear the rear diff. to match, and depending on which diff. you have.
(I'll install and provide new Yukon gears and master kit in your rear diff., $350.00 to $450.00 depending, includes parts and labor)
Option 5:
My D35 housing with Detroit Locker and Yukon 4.56 gears
(Installed in your vehicle, $500.00 includes parts and labor)
Disclaimer: D35 housings are generally not durable enough to reliably run larger than 33" tires and can break much easier with smaller tires than most other differentials.
I am not a vendor or shop owner and I hope i'm not breaking any
rules.(I manage a body shop and I would use this shop when installing these parts). I am just a member with some spare parts for sale and I have the ability to install them. I am also not looking to become a gear installer for hire, i am just willing to install these parts and whatever parts on your vehicle that would be needed with these parts, to match gear ratios. i would only be willing to do this at my location in Northglenn, CO.
Many of you know my qualifications:
I was a mechanic for over 15 years and I have done many gear installs.
I am the builder of The Xota.
My D44 install write up
http://naxja.org/forum/showthread.php?t=90711&highlight=pictorial
I also demonstrated D30 gear installation at our last Colorado Chapter tech. seminar.
http://naxja.org/forum/showthread.php?t=103040
My SYE write up
http://naxja.org/forum/showthread.php?t=74749&highlight=pictorial
I paid $350.00 for the Tru-trac new
I paid $540.00 for the Detroit new
PM me if your interested or want to discuss other options, different gear ratios? ARB install? Purchase parts only, etc..
Most of these parts were posted on several boards when I installed them in my vehicle, with pictures, and I can give you links to those posts.
Terry
Option 1:
Option 2:
Option 3:
Option 4:
Option 5:
My SYE write up
Terry
