tetsulo
NAXJA Member #1239
- Western, MA.
I've searched and haven't come up with an answer that is satisfactory to me, so I'm going to ask a gearing question. Here is what I can tell you...
I have a 1990 Jeep Comanche with an AW4 with 120k miles and a blown headgasket.
I have a Dana 30 and a 35 with 3.55's as best as I can tell
I'm running 31x10.5 AT's with 5" of lift.
I have a Golen Stroker kit on order. Should be ready for pickup in a few weeks.
With the stroker I am having these items installed.
24lbs fuel injectors
map adjuster
hesco adjustable fuel pressure regulator
hesco high flow water pump
borla header
rusty's xj air tube + K&N Filter
artsound 59.5mm throttle body (wonder if I'll ever get my money back from xj-armor )
random technology high flow cat
High flow thermostat housing
180degree thermostat
3 core radiator
Probably a 2.25 exhaust with a flowmaster of some kind (this has not been decided and I'm looking for recommendations on this as well)
The truck is primarily a DD with fairly long east coast highway runs involved. long windy hills etc. I would estimate I travel 600 to 700 mile a month for job related stuff.
From what I have read consensus says that 4.10's are the way to go with 31's. I dig that.
My question is -- do I HAVE to do the change right away? I didn't budget for the cost (of a gearing change), but I don't want to fry the transmission or cook the engine or anything silly.
Should I just stop using overdrive and leave it in third until I get the gears swapped?
thanks in advance
tetsulo
map adjuster
borla header
3 core radiator
thanks in advance
tetsulo
