DutchVDub
- Milliken, CO
Well just as an update, after multiple wheeling trips and a good 3000miles of pavement pounding the axle has yet to give out on me.
DutchVDub said:Well just as an update, after multiple wheeling trips and a good 3000miles of pavement pounding the axle has yet to give out on me.
Wheew! I just had a Skully moment..... :yap:
the D35 should be a front axle............... you can break the things on the street driving normal................
oh wow so they ARE that bad...wow...ok then....lol.....
Depends on what you get a donor axle from, if you get say a 96+ 8.25 with 29 spline or Dana44 out of an XJ they are bolt up just need to make sure your gears match front and rear. Many people around here able to help you with that.................so my next question would be....
how mechanically inclined do you have to be or special tools you need to swap a rear end?
If you get something not off of an XJ just make sure the bolt pattern & width matches. All it is, is simple fabbing work to re-mount the spring perches and shock mounts............again many people around here can help you with that too :cheers:
