geepers
- East Stroudsburg, PA
Guys and Ladies,
Help me out here going crazy !! Below is a posting I did weeks ago .. Just wanted to bring you all up to speed ..
After four weeks in cold weather , rebuilt NSS, new CPS, wires , rotor , cap, battery and removed wire harness to check for shorts also while I was doing it front left axel , brakelines , and alot of hair pulling !!!!! Guess what guys I should sell this on line for the tip of the year after reading all the threads about xj no starts ... I will release it here first , however still in testing of day two ... She starts ... I replaced the ignition switch and thought the problem was sloved .. NOT !!! Oh also I gave the fuel pump a shot and bypassed the fuel pump relay to give her a full 12 volts instead of 6v , yes the fuel pump will handle it ..
Week 6 and guess what ?? At times I have no starts and at those times I hear no fuel pump when I turn the key ,, So I turn on and off and on and off untill I hear a fuel pump and she will try to start however sounds like it is flooded .. I can get her started if I push the metal to the floor at which time it blows out the cylinders with major smoke and then she settles down to a 800 rpm and we are on our way ..
Man guys and ladies any idea ?? Is it a fuel pump ?? Should I just plant flowers in her and see her everday ?? I love her but sometimes enough is enough .. ( incase you forgot see above )
Thanks for your help in advance ..
By the way just got my personal plate for her ... Look for Me .. [G PURRS] in PA ..
