- NE Indiana
So I finally got the jeep together (pics later) and took it wheelin this past weekend. I'm running a 95 so I have a return fuel system. I'm using the e2000 pump and the holly dual pickup system. The tank has a rollover valve built into it. Off the rollover valve i ran a line up the back of the jeep with a small filer on it to keep debris out of it. Here is my problem.
When decending a hill i get fuel leaking out of the vent. Sometimes while just sitting on level ground with the jeep running I will get fuel leaking out of the vent and sometimes, fuel will spray out of the vent. How can I mount this thing so that I dont have gas all over the back of my jeep.
It also should be noted that while wheelin the outside temp was in the mid 80s, if that makes a difference.
mac 'no smoking around my jeep' gyvr
