FS: JKS, Hella,Daystar,Flares, CB, spare oem parts
chasdb
NAXJA Member 3643
Fullerton, Ca
Changing things up a bit so I got some parts for sale. Reply to post or pm me, Thanks Charles
JKS Discos for 3.5 to 6" lift, with swaybar and newer swaybar bushings $90
Hella 700FF with HID conversions and covers $100
Daystar bumps for late model XJ, cut down 3/4" from full length $25
Rustys Standard cut out rear flares $100 slightly trimmed
Ruffstuff Limit Straps 12" $30
Uniden 538 CB w/weather, comes with angle iron tail light bracket mount, FireStick antenna, spring and coax $75
Gauge pods with VDO trans temp and air pressure gauges with 1/8" npt temp sender and air line kit. Can't use it with my cage, $80
2 Dana 44 thick covers (factory Dana front) 10ea
stock xj pitman arm 10
Right drivers side fender in Silverstone metallic, good condition $50
'00 power steering pump complete with pulley, reservoir and lines 40 Not sure exactly what years are the same.
Rusty D30 front shafts, 40
Charles, are the Rusty's the later flexy or the hard plastic?
Hellas sold to Lurch
shafts pending to PahlMc
discos sold to crash02
limit straps, stock pitman arm, and power steering pump pending to garret83
Charles I'll take the poly bumpstops
they are yours.
discos sold to crash02-shipping out ups today, my post office is out of sm and med flat rate boxes.
limit straps, stock pitman arm, and power steering pump sold to garret83
bumps to karstic
Thanks!:geek:
Interested in D30 shafts. Put me in line if others fall through.
Can anyone confirm these work with an ected locker installed? I have no clue.
I am in OC.
just got the discos, thank your very much sir.
your welcome.
shafts sold to PahlMc
bumps to karstic
cb pending to newheep
