Mike L
- Anaheim, CA
I am trying to organize my garage and have some items I would like to move and create some space. Parts are located in Anaheim, 92808. Arrangements can be made to pickup along the 91 freeway between Anaheim, 92808 and Compton, 90220. First with cash gets them. Thanks.
I have a new Synergy PPM-8230 Jeep Cherokee XJ Front Long Arm Frame Bracket Kit - $250
Synergy's Jeep XJ Bolt or Weld on Front link brackets are designed for Jeep enthusiasts wanting the next level of performance out of their rigs. The kit allows for unlimited, unrestricted wheel travel without increasing under/over steer driving characteristics. The kit can be bolted into place and run or it can be welded to the sub frame to increase strength on the chassis.
I have a new T and J Performance BP-S1005 Jeep Cherokee XJ Shock Mount Conversion Kit - $80
Conversion Shock Brackets for the front of the 1984 to 2001 Cherokees. This bracket bolts into the factory upper shock location and conversts the mount from a stem system to universal eyte mount. The kit will accommodate Bilstein, King, Swayaway, or Rancho shock absorbers.
I have a new JKS Manufacturing 9604 Jeep Cherokee XJ Rear Upper Bar Pin Eliminator Kit - $45
JKS Bar Pin Eliminators prevent distortion of the shock absorber bushings by adding lateral compression, or preload. This ensures the bushings maintain their shape and deflect suspension impact forces to the shock absorbers, thus preventing the annoying noises and premature bushing failure common with standard bar pins.
I have a new JKS Manufacturing 1100 Jeep Cherokee XJ Front Adjustable Bumpstop Kit - $80
Adjustable BumpStops from JKS eliminate the guessing game of choosing the proper bump stop lengths for your application. This innovative solution utilizes a system of three interlocking billet aluminum spacers, each a different size. Adjusts to 0.75/1.25/2.00/2.75/3.25/4.00 inches.
I have a new Daystar KJ09122BK Jeep Cherokee XJ Extended Rear Bumpstop Kit - $45
Daystar Rear Bump Stops are designed to provide increased strength and less deflection under load. These bump stops are made high quality polyurethane that ensure long lasting durability. They facilitate easy installation.
I have 2 new Crown 52002393 Jeep Cherokee XJ/MJ 4.1" Extended Rear Axle Snubbers.
I have a new aFe Power 54-10422 91-01 I6-4.0L Jeep Cherokee XJ Stage 2 Pro 5-R Cold Air Intake System. My asking price will also include a 28-10014 Blue Pre-Filter and a 90-50001 Aerosol Restore Kit (Blue) - $300
This Stage-2 cold air intake system produces 9hp and 14lbs. x ft. torque. Enclosed in a durable 18 gauge, powder-coated heat shield; this air intake system features a washable/reusable conical air filter that improves airflow for increased horsepower and torque. This intake system also features a heat-insulating molded plastic tube that replaces the stock intake tract and directs increased air flow with improved volumetric efficiency for maximum performance. One-piece heat shield requires no assembly and the filter is constructed with 100% polyurethane for long life and multiple cleaning cycles.
I have a new MAC Tools West Coast Choppers Jesse James Signature Series 2 Piece Air Tool Set which includes an Angle Grinder and Cut-off Tool along with carrying case and accessory kit - $120
Angle Grinder - 22,000 RPM - 1/4" NPT Air Inlet - Variable Speed Safety Throttle - 90 Degree Angle Head for Maximum Versatility - Cast Aluminum Body with TPR Over-Molded Comfort Grip - Chrome Plating for Superior Corrosion Resistance
Cut-off Tool - 20,000 RPM - 1/4" NPT Air Inlet - Variable Speed Safety Throttle - 360 Degree Rotating Steel Guard for Optimum Safety - Cast Aluminum Body with TPR Over-Molded Comfort Grip - Chrome Plating for Superior Corrosion Resistance
