I have a brand new Hella SuperTone Horn Kit that I am not going to use. This is the kit with low tone horn, high tone horn, and a relay. I would like $45 for it.
Thanks. They are really easy to install in a Cherokee: bolt them on, connect the plug from the current horn and make a ground cable from the other connector.
Thanks. You connect the one factory connector and make a jumper from the second connector to a ground source. I used the mounting bolt as stated above.
