FS: Dana 44 Front Axle & Air Locker
XJsportG
SouthEast #4328 (RVA)
Richmond, VA
1979 Ford F150 Supercab / F250 Leaf Sprung Dana 44 Front Axle
Dana 44 from a 1979 F150 Supercab, these were leaf sprung Dana 44s with 5x5.5 bolt pattern. The housings are identical to the '79 F250 Dana 44 that had 8x6.5 bolt pattern, expect the spring perches are closer I believe and the spindles are slightly smaller, but don't quote me on that. Housing has 3" Axle Tubes with .5" thick walls, and all the stock brackets still welded on. Great axle for swapping into a XJ, highly sought after because of the bigger/thicker tubes, and having the welded, not cast, leaf spring perches.
Includes:
  • Ring & Pinion with open carrier unknown ratio, whatever stock may be.
  • Inner & Outer axle shafts (no u-joints)
  • Spindles
  • Caliper Brackets
  • Locking hubs & hardware
  • Calipers (probably good for core)
  • Knuckles still attached
Missing:
  • Hubs & Rotor
Yukon Zip Locker for Dana 44 with 30 spline axles, 3.92 & up (YZLD44-4-30)
NIB! Never been used or installed. Comes with all the original supplied parts from Yukon for installation.
Included:
  • Locker
  • Bearings & shims
  • Air Hose
  • Electrical Switch & Wiring
  • Other small parts
