Beezil said:willis, screw the 4-link.
just build one of these instead:
B,
I think you finally hit the nail on the head of where this thread is going!
hinkley
Goatman said:Back to the subject matter. Steve, what are your thoughts on wanting a triangulated upper link/links so you get rid if the track bar? I realize it's something different, but I just don't see anything negative about a front track bar, and there are definitely some things that are positive especially if you'll drive it fast off road and on the street.
Willis said:3 mid arms like your's intrigue me (or any asymmetrical system for that matter). The issue I see with this design, is that when drawn from the side with 2 arms (left side), you can calculate an AD%, and make that a respectable number. When drawn from the side with only one lower arm (right side), you can not calculate AD% because of the missing link (I don't know if the AD% would be infinite or not). What does this have to do with handling? Well, the way I see it, the AD% for the front, as a whole, will be what the AD is on the left. However, when in a hard braking situation with high traction, that left anti-dive is going to keep the left side of the frame rail from diving. The right side does not have any upward force from the upper control arm, and will dive more than the left. When the right dives more, it may reduce the angle of the lower control arm. By doing so, may push the right side of the front axle forward inducing a leftward brake pull which may be exactly what you want to avoid in a panic situation. Of course, this is my postulation on what could happen. Have you experienced this yet?
4 mid arms with track-bar. This option really has not been explored (Kinda by Tomkin, but not really what I'd want), and would probably net a fairly good suspension. The problem I see with this type suspension, is the fact that it creates a twisting bind upon full flex where all 4 mounts are fighting each other.I am thinking Rock Ready, no compliance arms that break the front axle bridge. This idea is still on the back burner, I may explore it some more. Rubber joints on the axle end would be a must.
Steve
Steve
Willis said:Thanks guys for the real world experience. That is definitely an option. For some reason I thought Goat's was on the drivers side as well.
I'll really look close to the 3 arm thing. Just out of curiosity, how long are your upper and lower arms (both Mark and Richard)?
Steve
Goatman said:My lowers are 19.5" and my upper is 16.5".
Beezil said:Goatman, why right side?
someone pointed out to me the drastic pinion angle that would result with the drivers side at full droop with running only a pass side upper. I didn't think it was a big deal when I was in the building process until I forklift tested it....
I've run single uppers on both sides, never had a problem, but I was just interested in front driveshaft u-joint life and ran the upper on the drivers side for the remainder of that set-ups life.
what's your excuse?
