Front Seat bolt size
sasq40
alberta,canada
Wondering if someone could tell me what size the 2 bolts that hold the front of the seat down. Had to replace my whole floor and now i just need to bolt it back together to drive again
mine werent bolts they were studs. (renix)
They can be, studs will also be threaded M8-1.25 (use flanged nuts or nuts and washers there as well.)
SAE8 and SAE5 won't apply - they're metric (ISO.) ISO fastener strengths are called out by "property class," which is a numeric coding stamped into the fastener head. You'll want to use ISO PC 8.8, 10.9, or 12.9 - 8.8 or 10.9 will be easiest to find, and plenty strong enough. After all, that's what's holding my seats down...
