Wil Badger
- Utah
if that was the case when i came to such an obstical i would let you go first then you could strap me .sure my winch isn't good for all situations but its also using your brain in certain situations.
dmillion said:Same thing that happens if you have a fixed-mount winch... you get muddy.
Have you actually been in a situation where the 30 seconds it takes to mount a receiver winch would make a difference? I haven't.
Then you mount the winch on the other end. In fact, this is where a receiver mounted winch is really much better. If your front end is so jammed down into something that you can't mount the receiver winch there then it is almost certainly so jammed down into something that a fixed-mount winch wouldn't do you any good.
I have had fixed-mount winches before. As someone else said, "had" is the operative word. I would never voluntarily go back to a fixed mount winch. The receiver-mounted variety works just as well, doesn't limit approach angle as much (since it's not mounted unless it's needed), reduces weight when I'm not wheelin', and improves the security and longevity of the winch itself.
FarmerMatt said:On a personal level & having been "there". If I see that you have a multimount winch than I'm going to put myself as far away from you during the trail run as possible. I learned my lessen in hauling not one, but 2 mutimount winches up a water fall & having to "install" them while the buffoon's with these contraptions sat vetical on the said water fall waiting to get winched up. With the winches installed they couldn't get close enough to even start up the fall. Buffoon's names are withheld since they came to their senses shortly after said event.
dmillion said:Well, I'm not going to get upset and take it personally that some people prefer a different kind of winch mount than I do. I'll just repeat that I've had both and I much prefer the multi-mount for the reasons I've listed. All of the objections to those reasons seem "pretty silly" to me, to quote someone else. Maybe that's because we do different kinds of wheeling. I don't know. I don't care. I just know that I've owned and used both types and I'm sticking with the multi-mount.
jmsull said:I had a YJ before my XJ. I had my winch mounted perminatly on the front. I only got stuck in mud once to the point that I needed it. It was on a very narrow trail with nowhere to turn around. I had to winch myself forward for a a good quarter mile before I could turn around. That meant setting up around a tree a good ten times in each direction. Both my batteries died a third of the way back after I turned around. I had to walk out of the woods with my battery, charge it over night and walk back in the morning to finish winching myself out.
If I could have winched myself backward, I only would have had to do it for five feet, instead I did a half a mile worth of winching over two days to get out.
I have a receiver on the front and back on my XJ for this reason alone. My winch goes where I need it when I need it and it sits in the basement safe and sound when I'm not out wheeling.
I agree it is a matter of what kind of wheeling you do. Mine is in the mud where being able to go backward five feet will save you hours upon hours of labor.
Oh and by the way what do you think is more of a work out, getting a winch out of the car once or setting up a snatch block twenty times?
XJ_ranger said:run the vehicle while winching - batteries last longer that way
Bent said:in the dark by myself.
gearwhine said:There's your one major problem right there. :lecture:![]()
Lawn Cher' said:x2... been there, done that, then I joined.
