Front end supension (4 bar link calc)
Finaltheorem47
Virginia
Hi, I'm designing the front end suspension for my XJ and I'm pretty sure I got what I want. It will have the 4 links plus a track bar and the main purpose of my XJ is a daily driver so street performance is priority while offroad characteristics is secondary.
Can someone take a look at my numbers and tell me if I'm doing anything wrong?
http://www64.zippyshare.com/v/gPrbWt3g/file.html
Thanks, Finaltheorem
Might be easier if you post screen shots, as people aren't going to want to download a file.
I'm a little confused, what type of 4-link are you looking to build?
If you're looking to build a dual triangulated front 4-link, you shouldn't need a panhard (trackbar).
As well, a 4-link with good number's doesn't really fit on the front end of an XJ without major modification.
If you're not trying to do a dual triangulated 4-link, then I would look at doing a 3-link with panhard.
While I would have loved to been able to fit a dual-tri 4-link up front in my XJ buggy, I went with a 3-link with panhard since I still wanted a LCOG rig and nothing hanging below the belly.
Good point, let me snap a screenshot:
Not to be a jerk but if your goal is to DD and sometimes offroad a Cherokee, why not just do that? You shouldn't need a custom 4-link to DD & occasionally drive down a trail...
If I were you, drop playing with the 4-link calculator, and pick up the 3-link w/ panhard calculator.
Even then, it's "meh" for a 3-link in respect to an XJ front end.
For an XJ front 3-link with panhard:
- Keep the lower links as flat as you can at ride height
- Try to make them somewhat longer, and tucked up if possible
- Put the upper link where it fits
A 3-link on the front of an XJ is more of "put stuff where it fits" kind of thing.
To get good "numbers" with a front 3-link (and really 4-link as well), you'd need to have your upper(s) above the current floorboard.
Search around here for three link fronts, and then try to mimic them :D
