front door locked and wont open!
ConnorMann
Chicago
93 xj w/ power locks
the button to open the door has no pressure, the manual lever inside does not unlock door.
I removed the inside door panel, not easy.
How do I get the door to open?
push pull on rods?
thanks
My rear door is doing the same thing. Without opening the door I can't pull the door panel to gain access. I suspect a rod has come off something. Really a PAIN!
The rods use little plastic retainers to hold them in place. One may have broken or slipped off.
Good luck!!
