boomer1
- Northglenn, Co
Hi
Quick question - On a 1988 cherokee, is there anyway to pull the bump stop out of the center of the front coils. Going to replace front coils this weekend, 3 1/2 inch RE lift. From what I understand I need to support the front by the frame, pull the tires, disconnect the control arm, sway bar and shocks and then I should be able to get the coils out. Hopefully without screwing up the brake lines. I do have a set of spring compressors, but from just looking at it, if there is someway to drop the bump stop, it looks like it would be a lot easier.
Thanks, as usual everyone has always been a lot of help with my cherokee projects.
