1988 Cherokee Larado AW4 NP241 Dana44 rear.
I bought this truck last week for 1200 bucks, I bought the body and knew it had some mechanical problems.. well now I am trying to fix the brakes, the front ones will drag.
I have replaced the master cylinder, and both calipers and pads.
the previous owner must have attempted to fix this and other things and now I am trying to fix them CORRECTLY..
the brake pedal can pivot all the way to the bottom of the dash and sits up well above the accelarator pedal. I know this is not right and might be contributing to my front brakes locking up.
I looked under the dash and saw this part.. what is it and how do I adjust it? it was screwed ALL the way back(towards dash away from firewall) and bent over to the side, the brake lever would not contact the switch at all. plus it had a vacum line attached to it.
I have a feeling my booster is gone... but maybe not. How do I adjust the rod, maybe my master cyclinder is not disengauging all the way.. when I took the old master cyclinder out, the rod could be removed from the brake booster, is it supposed to do this? I don't remember my f150 booster to be like this.
here is a pic of the pedal height. it seem WAY to high..
sorry about the size... didn't have time to shrink it.
any tips,pointer, or help would be greatly apprciated.
thank you
thank you
