IslanderOffRoad NAXJA Forum User NAXJA Member Location Houston, Tx Sep 9, 2021 #1 For an XJ with 3.5-4.5" lift. About 6 years old, still work great, no leaks, couple little boot tears $80 for the pair.
NOTNSUV You Guys ROCK! Location Spring Creek, NV Sep 13, 2021 #2 IslanderOffRoad said: For an XJ with 3.5-4.5" lift. About 6 years old, still work great, no leaks, couple little boot tears $80 for the pair. Click to expand... Will these work on rear of coil spring WJ, ya know Grand? Sent from my Pixel 4a using Tapatalk
IslanderOffRoad NAXJA Forum User NAXJA Member Location Houston, Tx Sep 14, 2021 #3 NOTNSUV said: Will these work on rear of coil spring WJ, ya know Grand? Sent from my Pixel 4a using Tapatalk Click to expand... As these have the stem mount up top its the wrong configuration for the rear. I checked and the part number is the same as the front. https://cart.bilsteinus.com/Portals/0/PDF/BILSTEINORCatalog2020_WEB.pdf
Swamprat NAXJA Forum User Location little Tijuana Sep 15, 2021 #4 too bad you are way south of me, i'd buy them
IslanderOffRoad NAXJA Forum User NAXJA Member Location Houston, Tx Sep 16, 2021 #5 Swamprat said: too bad you are way south of me, i'd buy them Click to expand... Man I was up there Monday too.
Swamprat NAXJA Forum User Location little Tijuana Sep 16, 2021 #6 i saw that, i was on the fence and wasnt sure if i wanted them.
