Front axle shaft boot?
1985xjlaredo
Kansas City
Well I went out wheeling last night and broke what ever is under that boot on the passenger side. When I got to pavement i stuck my finger through the boot and a big round bearing fell out.
Do I have CV joint or do I have u joints under those boots? I've never replaced CV joints before on anything. What is under that boot that broke?
yep. replacing the CV shouldn't be that hard, but it may be expensive.
My recommendation:
Go to the junkyard and pull some u-joint shafts from a newer XJ, replace the u-joints and install those. U joints are about $15 a pop, I bet that CV joint only comes as part of an axle shaft, and they're probably $100 a side at the local parts place.
Could I just buy the newer style axle shaft with the U joints and put those in place of the CV joints. Are the U joints stronger?
?? wHAT YEAR WILL FIT? I,VE SEARCHED AND i CANT FIND A CROSS REFERENCE.
