Looks like a stock 4.2 crank.gradon said:505 performance. I thought the crank was forged, but now I'm not sure.
http://cgi.ebay.com/ebaymotors/Jeep-Rubicon-AMC-4-7-Stroker-Kits-WOW-L-K_W0QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247QQcategoryZ33623QQihZ004QQitemZ140008963046QQrdZ1QQsspagenameZWD1V
REDXJ4FUN said:FYI the 199 amc six had a forged crank
Been thinking about all of those. Don't need glow plugs, can simply use an air intake heating grid similiar to the cummins.Bryson said:lol 18:1
if you wanted to swap to diesel, compression is the last thing I'd be worried about. More along the line, of how the hell are you going to swap to a high pressure fuel injection that is capable of idling the motor or...glow plugs perhaps? good luck with that. Not to mention your cylinder head isn't designed for a compression related combustion.
The list goes on.
Bryson said:It just seems your money would be much better spent else where.![]()
KMK172008 said:you have to upgrade almost everything the eathanol touches if your gonna run it off of e-85. also expect a huge drop in fuel economy.
