Ford 9in. 4.88 gears, trac loc limited slip
440swepty
Savannah, GA
I have a complete Ford 9in. w/ 31 spline axles. It has a brand new set of Motive 4.88 gears setup w/ a solid pinion spacer and a used Trac-Loc limited slip. The housing has XJ shock brackets welded on but has factory F150 spring perches (3/4" wider than XJ). The axles could use new bearings and seals and the brakes could used replaced. I was going to use this axle but decided to go a different direction. $450 OBO
Thanks, Kevin
wanna trade for a 9 in with a spool and 8.88s? ;) its got 35 spline axles........ ;)
Hard to pass up but NO THANKS! Have you wheeled that 99 any?
yea i take it as often as i can but with my wife deploying im wonder dad and all my toys are back burner status.
there is a local mud bog but id rather find some rocks or trails ya know ;)
