Lonestar
- west bountiful utah
I am in the process of setting the new 9" in place. I have it centered side to side 7 1/4" from the spring perch to the bearing flange. I have also set the pinion angle so that it is pointing at the output on the tcase (so far so good). But with the driveshaft in place the it is not straight. It looks like the pinion on the axle is not in the center of the axle, but the axle is centered under the chassis. Is this normal or have I done something wrong? Keep in mind this is the first time I've done anything like this so let me now if I've done something wrong.
