Ford 9 inch rear
89Mock
Reno
I have two Ford 9 inch rear ends. Original plans have changed.
First one is out of a Lincoln Versailles. It has a third member with 3:70s gears, 28 spline axles, big bearings and the caliper mounting brackets. No studs to mount the third member and those are $15 at summit. Coil springs brackets were cut off.
$300 OBO.
Second one is out of a Bronco. 31.5" long 31 spline axles. 4.56 gears. Full spool. Axles look like they're 1.25" in diameter. C7AW E third member. Drum brakes included and not currently mounted on the axle. Spring perches were relocated in for a hot rod project that never happened. They're 42.75 inches apart.
$450 OBO.
Both are located in South Reno near Toll Road/Summit Mall.
