Having an issue where engine looses power after getting up to temp. Like 30+ miles at highway speeds. Thought to be a clogged catalytic convert. Getting more clogged when hot causing O2 sensor to give bad info for fuel air mix. Runs fine when in open loop. Need to drive the vehicle home from parking lot about 50 miles away
I actually don't know if it is clogged. That a shops opinion. No CEL. Something causing a bad fuel ratio after extended driving at highway speeds. After things cool off it runs fine. Even when I have the problem it will restart and idle perfectly. Any chance this could be a bad O2 sensor that's not throwing a code?
Dont bother with changing the thermostat,
... as, Open to Closed Loop, occurs quite quickly after startup - when the coolant temp is still as low as 70*.
I havent tried it ... but disconnecting the O2 sensors may well cause the PCM to apply the Open Loop fuel presets in relation to whatever coolant temps are relevant.
Cats get very hot when they're clogging up. If yours
is nearly cherry red, then it's indeed clogged. Running
in open loop still won't get you home; might be better
to loosen the cat flange so there's a gap for exhaust to
escape. Yes, it'll be loud, but you'll get home...
