for sale: XJ front floorpans, WJ LCAs, FSJ front DS, PS/ATF coolers, JKS TB
kastein
Looking to clear stuff I don't need out of storage.
XJ front floorpans, brand new, 100 for the pair
2x AW4 flexplates for 91-01 OBD I/II, make offer
Biiig ford trans cooler from some F series pickup, stacked plate style, 20 bucks
ZJ trans cooler, mopar part number 52006344, 10 bucks
FSJ or CJ front driveshaft, not sure, part number 53005541, 20 bucks
JKS XJ track bar, for 1-3.5" lift iirc, needs replacement split taper cone (9 dollars from jks), joint and bushing in good shape, joint was fully disassembled, cleaned, checked, and regreased. 125 bucks
WJ LCAs in good/decent shape, 40 bucks obo
Can deliver in central mass for gas money or if trading for parts.
Sure. They'll be sitting on the porch till then, no big deal.
XXXX..i need floors. Dammit billy
P/N: 53005541 also fits ~94/01 XJ's w/ 2.5L Engine.
You're kidding. I learned something today.
Hell it might have come off one of those. It came with one of my jeeps that also had a 2.5l fan + fan shroud sitting in the back, from bump, so there's a good chance they came from the same jeep.
:greensmok
I got em from one of the PA guys like 3 years ago and never used them. I can look at the part numbers if you want.
Billy, are you gonna put them in the XJ or the MJ or Maegan's XJ? Just so you know (pretty sure you do already, but might as well say it), they won't fit an MJ very nicely without a lot of hammer/grinder work, MJ floor pans are shaped quite differently. If it weren't for that I would have started installing them in my MJ instead of listing them here when I found them in storage yesterday.
I figured, wasn't sure if you ever did floors in an MJ though. They're yours :thumbup:
he likes a good rotten bottomed 'manche I guess
Your PM box is full. Which JKS trackbar is this? Fixed length or adjustable? I'm interested.
Its adjustable - as I recall, the one for low lift not high lift.
I will empty out my inbox a bit tomorrow or something - in the meantime my cell is 774 922 2854 for anyone who doesn't already have my number.
Dave - these aren't high class enough LCAs for your build.
