jwdl21600
- Foothill Ranch, CA
I have a White 96 4 door XJ, 4.0, 231, AW4 for sale $8,000
FRONT SUSPENSION
Rock Krawler 3-link
RE ZJ 4.5 coils
ACOS
Custom over-axle track bar W/ RE HD mount
Rancho 9000x shocks W/ JKS adapters
REAR SUSPENSION
National 10-leaf pack
ORGS boomerang shackles
Bilstein 5125's
FRONT AXLE
Dana 30
4.88 gears
30-spline ARB air locker
30-spline chromoly inner axles
Warn 5x5 hub conversion with 30-spline stubs
CTM u-joints
WJ brakes W/ 2-piston calipers and seperate draglink and tie rod
1 ton tie rod ends
1 1/8 .188 wall used for draglink and tie rod
REAR AXLE
Dana 44
4.88 gears
33-spline Detroit Locker
33-spline chromoly shafts (dual pattern, currently in 5x5.5 )
Torino style housing ends to use larger Timken set 20 bearings
Explorer disc brakes W/ functional E-brake
INTERIOR
Mastercraft Rubicon driver/passenger seats
Stock rear seat
New digital cammo headliner
Custom cage Interior/Exterior
Pioneer cd player
Uniden 510 xl cb
315/75/16 spare mounted flat in the rear
Air Tank mounted behind driver seat for OBA
EXTERIOR
ORGS front winch bumper
ORGS HD cross member
Fully welded SBS inner and outer plates on both sides
ORGS supernerfs
Custom rear bumper
NEW 315/75/16 BFG MT 2
NEW Procomp black steel rims
Wilson 1000 CB antenna mounted on the roof
Some dents and scratches from mother nature
MOTOR
Stock 96 4.0 HO
184,000 miles
K&N FIPK
APU Stainless header
Jeepers & Creepers bored throttle body
Turbo City throttle body spacer
Power steering cooler
Trans cooler
Upgraded cooling system with 2 row Modine radiator
NEW AC system
New cap,rotor,8mm wires and plugs
New water pump
New O2 sensor
New MORE motor mounts
New 4 nozzle fuel injectors
New fuel pump
New fuel psi regulator
FRONT SUSPENSION
Rock Krawler 3-link
RE ZJ 4.5 coils
ACOS
REAR SUSPENSION
Bilstein 5125's
FRONT AXLE
Dana 30
4.88 gears
CTM u-joints
1 ton tie rod ends
REAR AXLE
Dana 44
4.88 gears
INTERIOR
Stock rear seat
Pioneer cd player
Uniden 510 xl cb
EXTERIOR
ORGS supernerfs
Custom rear bumper
MOTOR
Stock 96 4.0 HO
184,000 miles
K&N FIPK
Trans cooler
NEW AC system
New water pump
New O2 sensor
New fuel pump
