Thanks guys, Cracker is explaining it pretty much to the T I think, but I have ridden in Vanimals rig and it does ride super nice!
My goal is to things spot on as far as equal angles an lengths go. I am goin ton use Heims all around with hydro assist, all of which has been on order and are waiting for delivery, just need the DOM tube, which will be 1.5", .25" wall.
Nelson!! I need to get those harnesses from you!! Are you going to goatfest?!
My suggestion is to run heims as you see in the pic above with the inverted T I posted. On the draglink there is one heim and one TRE. Also note that there are cotter pins and safety washers used along with fine thread grade 8 hardware.
I highly recommend a Chevy 1 Ton TRE at the pitman arm cause if its ability to take lots of angle...I have never liked heims single sheer with high misalignment spacers at the pitman arm unless it was a twisted pitman arm like from Genright.
3/4" rod ends are becoming more and more available and out in the desert most of us run them and have spares on the trailer.
