The track bar and tie rod are both completely temporary!! I am ditching the drop rustys mount and using an outside frame mount from rough stuff an an offset axle mount from ruff stuff as well.
I do plan on doing what Cracker said, and what vanimal suggest a few weeks ago, and push the track bar forward a bit.
The drop pitman arm definitely has to go, and I will replace with a stock to start. I plan to do a cross over steering set up with the tie rod mounted over the knuckle.
I am pretty nervous about using my tiny welder on the front axle. I have been reading a lot about the guys on here doing okay with it, but I do plan to hammer on it close to home once I get this rolling. If it doesn't hold, I should know pretty quickly!!
