- Billings MT/Rapid City SD
Finaly got some pics of my crossmember. Built out of 0.1425" steel, sides are boxed with rolled lips and the inner section has gusset to stiffen/strengthen then structure. I post cad files of it awhile ago. Tranny mount is the same idea as Jess used on his except I just welded the bushing to the crossmember. Had it one for 3 odd months and it seems to holding up fine. It mounts by the two bolts in the frame rails. Welded a plate with bolts in the rail and bolted to that. Not sure on the thin steel but thats all the place I was using could bend given the shape so we'll see if it works. Also in the works are a section behind and ahead for t-case and tranny protection.
