Fixed my overheating XJ...
Mudd
My 88 XJ had been heating up regularly with the arrival of warm weather. After I got my A/C operational it only got worse. I got a lot of excellent advice when I presented the problem in this thread:
http://www.naxja.org/forum/showthread.php?t=85652&highlight=hiway
I decided the radiator was the culprit based on a few observations:
1) During the first drive of each morning the radiator is nice and cool. As the temp gage makes its first climb and the thermostat opens the temp gage shows a sharp drop. Then it climbs again and drops a little less. The cool radiator is now being heated up. Then it doesn't drop anymore. It just steadily rises regardless of driving conditions or speed.
2) When it looks like a trip into the red zone on the gage is inevitable I turn off the a/c and turn on the heater to full blast. This does not have a favorable outcome with passengers when outside temp is already 100 deg f.
It does, however, drop the temp a little.
So it looks like the radiator is just no longer up to the task. This is the original closed cooling system, by the way.
I called a 1-800-radiator place from the yellow pages and they brought me a Modine 3-row to my house within 2 hours for 140 bucks.
I recently moved, I don't have all my stuff yet, I have a gravel driveway to work in, and it's 100 degrees again. So I didn't run any flush through the system and I didn't pull the block drain. I did do some flushing though:
I pulled the old radiator. I pulled the hoses from the heater core. I pulled the thermostat housing and thermostat. I pulled the temp sensor from the back of the head.
I used a pointy sprayer on the end of my garden hose to flush the heater core in both directions until it came out clear. I stuck the nozzle in the temp sensor hole until the lower hose ran clear, then put my hand over the end of the lower hose. This caused the water to go through the block and come out the front of the head, eventually running clear. Also in the front of the block I could see a water passage on each side of the head. I forced water in one hole and it eventually came out the other hole. Once everything was running clear I figured I was pretty well flushed. This left some tap water in the block and heater core but my well water does not leave mineral deposits on the fixtures in the house so I figured what the heck, good enough.
I buttoned everything back up but left out the temp sensor. I think the system capacity is around 3 gallons so I added 1-1/2 gallons of antifreeze to the pressure bottle. Then topped it off with distilled water until it started spewing out the sensor hole. Then I put the cap on the bottle. This stopped the flow from the sensor hole. I installed the sensor and ran the engine and checked for leaks with the cap off the bottle. You can see some air being purged as the return line dumps into the bottle, which is the highest point in the system. Then I pulled the sensor again. I slowly loosened the cap on the bottle and a little trapped air came out of the sensor hole. I closed the cap to stop the fluid flow and installed the sensor. That should leave it pretty well burped.
I went for a long test drive in the hot weather with a/c blowing and the temp gage never crossed over the 210 mark. Success!
I wanted the fastest, easiest, lowest cost repair so I kept the closed system and upgraded to the 3-row.
Hope this helps anyone suffering the dreaded cooling problems...
John.
This is exactly what I am looking for. I've flushed the system, put a new radiator and a new lower hose with spring and it still runs hot. It gets worse at highway speeds. The one thing I did not do was pull the sensor. This may not solve my problem but it gives me something else to try.
You may have a water pump issue. The impellers can wear down or break completely, causing inefficient coolant flow. This would explain why it runs hot at highway speeds (higher RPM), and cools down at slower speeds and/or idle.
I was wondering if it could be the water pump. It stays around 210 in town but once I hit highway speeds it starts moving up. I never thought that the impellers could wear down. Thanks!
89xj said:
overheating at highway speeds can also be the mechanical fan clutch not working properly.
you've got that backwards. Overheating at slow speeds may be the fan clutch. At highway speeds you're providing all the air the radiator needs.
I got the lower hose with the spring in it to prevent it from collapsing. I pulled the sensor and I think I got all the air out. It still over heats on the highway once I go over 65. It also over heats when I take a ride up the mountain even when outside temp is low 80s.
I noticed that my fan clutch has the same resistance when hot or cold. It turns but with enough resistance to only freely turn several inches.
I am going to go with the water pump first since it overheats on the highway. Then I'll go with the fan clutch.
I had a saga of trouble with the closed system in my old 89 XJ. New radiator, 2 bottles, 2 caps, water pump, and nothing fixed it until I did the cheap conversion and switched over to the open system. I used this part and got rid of the pressure bottle.
madxj.com has a great write up in the tech section.
