Sierra Drifter
- San Ramon Ca
Gaius said:TJ's mounts are lateral like that, but so are the tops. You shouldn't have any problem.
You could always use your sway bar mounts as BPEs to twist the upper mount to match.
edit: best pic of my TJ's mounts i have:
TJ upper shock mounts are angled tword the rear. XJ upper mounts are angled toward the center, on the oposite plane.
This picture show an XJ with a typical shock mount that pivots side to side, not forward and backward.
Notice the shocks angled toward the center of the unibody. When the axle flexes, the shock pivots on the correct plane.
