sardo_67
- western CT
Finally working on this toilet again.
9 center is all done, waiting on leaf perches to arrive and figuring out a leafspring bushing problem. Then the ass end is done.
D30 is under the front just waiting on a long arm to mock it up and see where the spring pads need to be welded to.
Major progress today on the new 4.0.
Block is line honed and bored 20 over
Prepped the rods, glass bead, magnaflux, cut the caps, cut rods, new ARP rod bolts and stretch checking. Will hone out to size next week.
Put the rear toolbox back in, had this tank laying aroun so I put it in. Probably more trouble than its worth because I know I'm gonna get stupid questions now.
If everything gets delivered like its supposed to it will be on all 4 wheels this weekend.
resized the rods..
WJ knuckel work
line everything up and mock it with an old hub
into the oven to prep the cast steel to weld
on to the bench, wrapped in a welding blacket to prevent it from cooling too fast
aaaaand now that fancy hot glue gun
done, this on all 3 sides of the spacer. he was bitching about the quality of that weld or something, idk seems good to me.
resized the rods..
WJ knuckel work
