Clean Racing
- Bellingham, Wa
holy tie rod! Im jealous!
Axle stats / doner?
What's with the 4.10 gears? Nobody does 4.10 gears anymore. 4.56 at least.
BTW, is that the tie rod or an axle tube? Looks BEEEEEEFY! :worship:
about time you got off your arss & got that thing together
BTW how much caster you running? I see you wrote 17 deg on the axle tube in one of the pics. That might be 10 deg too much..
Thanks for the donor info. How are you going to do the upper control arm mounts above the pumpkin? I've read that that area can be risky to weld on.
