If you are using your ercolina for large production runs, I would recommend keeping a log book of what the spring back and bend dimensions are for future use.
My experience with the ercolina bender is that they are better suited for production than one-off prototype work.
My best advice I can give you is to watch the wear on the brass follower die. It will wear over time and later when you plug in your old dimensions and don't get the same results, you will have to compensate.
Chris Amrein
