Feeler for sale of my XJ crawler.
1-tonxj
Colorado
Semi street legal 😀 it has a vin and has plates in my county but won't pass emissions because it has no catalytic converter and besides you're not driving 42 stickys on the road.
79 Ford 60 front axle ,rcv axles, Crane knuckles , Detroit locker 5.13 , spring eliminator, Crane diff cover, full truss. Yukon hardcore chromoly lockouts
Front suspension 18stx rebuilt 3 months ago fully updated to 2020+ parts ORI LEVEL IT. Radius arm with metal cloak lock and load to allow use of non rubber bushings, uppers 2 inch a500 square with emf off-road joints 3/4 thru bolts , lowers 2.5 inch a500 square with BALLISTIC fab chromoly joints 65 degree misalignment 3/4 thru bolts, lower joint synergy duoflex joint 18mm thru bolts . Clayton off-road Cross member.
Full hydraulic Steering 2.5 in psc cylinder psc pump, psc control valve and reservoir. Mounted on full c-c truss/mount.
Rear suspension 18stx rebuilt same time just like front, double triangulated link Clayton rear conversion cross member / belly skid. ORI level it
Rear axle .14bolt ballistic fab shaved ballistic hd cover. 4340 Yukon shafts , disc brakes Wildwood calipers, full truss tied into diff cover and pinion , welded axle tubes to center, pinion yoke guard , 5.13 , Detroit locker, Upper links 2 inch. 250 wall dom 2.5 Johnny joints 9/16 thru bolts . Lowers 2.5 a500 square with BALLISTIC fab chromoly joints 65 degree misalignment 3/4 thru bolts. 1310 double cardan at case 1350 forged yoke at axle
Transfer case, Atlas 2 5.0 with TMR rear support brace.
Engine/ trans stock 4.0/aw4 with full brown dog motor mount kit and an a radesign shifter sitting in a box ;-). 98k on motor and 80k on aw4.
Cooling -Triple electric fan on aluminum radiator b&m large trans cooler remote mounted in cargo area on cage with fan .
Fully plated frame from front horn to rear . boat sides, full exo cage , exo tied into bumpers and boatsides and strut towers , and tied into inner cage . Fuel tank moved into cargo area between frame rails and plates under the tank .
Tires and wheels 42 Maxxis stickys on 17 allied beadlocks almost full tread no cracking still soft and sticky.
Warm 9000I with warm wireless remote.
Sparco cheap racing seats 4 point harnesses
I'm sure there's more little crap but that's about it off the top of my head .
I don't use it anymore just sits on trailer in lot so getting rid of it seems logical but don't need the cash so don't need to give it away either !-)
I'm thinking $15k
