homebrew
- Bremerton, WA
Possibly for sale 91 XJ 4.0 HO 5speed. throttle bdy spacer.
4.5 lift comprised of a 3 inch RC lift with 2 inch spacer in front and MJ shackles in the rear. adjustable UCA's and LCA's tomken lower RE upper. modified adjustable trac bar(came off a TJ friend made some changes so it would fit the XJ. Open diffs with 3.07 gears. Currently running 32x11.50x15 BFG MT's on black rock crawlers. Jeep is all black. home made disco's.
A/C works 195K on the clock. Just drove it to florida and back no problems beside the obvious need for gears. fenders are trimmed air box is modified to take a feed off the cowl area. Jeep was in JP mag and on extreme 4x4 if anyone saves that show if you wanna picture. I might have some other pictures that I will look for. will also throw in a pace setter header and a winch plate from a hummer. Thanks for looking Paul PH 951-312-3407
