Feeler:4.56, detroit 8.25. Dana 30 4.56
Outlander560
New York
Rear 8.25 wire brushed painted black have about 4k on axle since install
Detroit locker
Yukon 4.56 gears
new drums, pads, hardware, new brake lines
Solid Diff cover
Jks Low profile shock mounts
Comes with e-brake cables
$700
HP Dana 30 housing wire brushed (no gears but have a set read further down)
-comes with new upper control arm bushings
-napa upper camber ball joints 1* tack welded on..was done very carefully
-Does not come with knuckles but i have other sets
-Can include extra shafts if you want
Bad:
DS lower control arm bracket cracked on one side all the way up and half the way on the other side I re-welded it was driving around fine and wheeled fine with it...strong...welded the inside and outside of the mount as well as the top..no issues with caster or any angles made sure it was done right
No lower ball joints
Without knuckles/shafts- $70
With knuckles and shafts-$120
Dana 30 4.56 ring and pinion for a HP30 was installed in the D30 above but when I removed them plans changed and I did not re install them
asking $90 carrier included as well
If you buy the front D30 with everything included the 4.56s I'll let it go for
$190 OBO
Needs new bearings and seals
If I can sell both axles together as a package set I'd let them go for $840
