Mike L
- Anaheim, CA
I tried searching and saw there is no real way to check the fan clutch. My car tends to run warm at idle but will go back down in temp. This makes me think the fan clutch is bad. It doesn't spin freely when it is hot and I check it but seems to not be as tight as a new one. Although I am not real sure since it has been about 2-3 years since I replaced it.
On occasion my rig runs hot going up steep inclines as well. The radiator is a GDI 3 core that I put in less than a year ago. I also replaced all the hoses at the time I installed it.
Any ideas? Has anyone welded the fan clutch so it is locked all the time? If so, are there any complications? I would think it would pull more air all the time since it will spin all the time with the belt. Thanks.
-Mike
-Mike
