YJ-GENRAL
- cleveland, TN
getting rid of the 44?
Nope, gonna put one in.
Why? Same joint. You tack your caps on alloy shafts and I bet your joint issues will go away in the front.
True about the same joint but I have broken shafts up front also not just the joints. Hopefully with a stronger shaft I can upgrade the joints and really not have any more trouble.
how can we forget! haha...If they make it, Mark can break it. Don't you remember Morris Mountain??
plus the housing/ring gear/tubes will be stronger
So what size tires you going to? I would recomend xj width by the way.
so you have a d30 up front? didnt know that.
^ Now thats some turning radius!
That's what I was thinking Tyler. The locking hubs would be the only way I could run a joint like a BLong.
