Fairly Simple Question
NW-ZJ-SCOTT
TEXAS-JT-SCOTT
NE Texas
I am in the middle of doing a WJ Knuckle conversion on my ZJ, I have done research for days now, I have everything lined up on paper.. Except the track bar..
I have narrowed it down to Ruffstuff, I'm certain i will need the offset bracket, I like the adjustability.. and i plan to place it between the coil bucket and the stock UCA bracket..
Where should i go for a "bolt in" frame bracket, and what track bar do i go with? i have measured 10 times now, and cant find a simple "order this one"
I like the full ruff stuff kit, But i want a bolt in bracket on the frame end, while trying to avoid spending $300 on one simple link.. :dunno:
Insight?
the problem is, Once you go Over the axle, its shorter.. I dont really want to buy one for $200 +/- and have to cut it and weld..
