- Rainy side of Washington
They are likely present on a 2WD because Chrysler did not want to stock two different exhaust manifolds.
That is where the dent is in my 99 ...lol djb that dent you showed isnt factory
I've found mine on my 98 cherokee 5 years ago when I bought it. I took off the pipe and heated it up and pushed out the dent. Never had any clearance problems since. I still have it today. Of course I never do any major off roading.
I heard from a Chrysler engineer buddy a while back that the "dents" in the later models were to help get the catalytic converter up to temp quicker.
i have three xjs and all have the down pipe where it meets the exhaust manifold are "factory crushed" to make them fit. is that right? just seems weird all 3 of them. the rest of the dents are courtesy of BIG rocks. the rest is missing .lol
Adding an adjustable track bar in just a bit... I do need to get some better bumpstops on, though. (Dick's has glow in the dark hockey pucks...!)
So, if I put on a non-dented pipe, I should get some horsepower improvement, or maybe MPG improvement?
I can't figure out which pipe is which, though. Morris 4x4 shows the '98 front pipe as being almost 5x as expensive as the older models (over $200 vs about $50), why the heck is that? Did something significant change? Rock Auto shows the '98 front pipe at the same price as the older ones... which is right? Are either of them "non-dented"? Is there a JY non-dent version? Am I over-thinking this?
(and I fully expect to keep denting stuff! ;-) It's a Jeep!)
