Factory alarm on a 91?
The other plus is that all the doors unlock at once as opposed to unlocking your driver door and having all the passengers try to open theirs as you are hitting the power unlock switch, then locking and unlocking them again and there is still somebody who insists on trying to open their door causing you to go through the same routine again or reaching over and using the manual button.....
sure this has happened to most of us more than once!
haha this happens to me ALL the time.
its annoying
ok i have a 1992 jeep cherokee sport does it have a alarm
don't know, go look? Can't really tell without looking at the vehicle
I'm curious... on a 1991-92 Cherokee, where did the factory locate the receiver if it doesn't have an overhead console?
On a plastic trim piece between the two sun visors.
The little black dome is just the lock/unlock receiver, AFAIK it doesn't have a dedicated alarm disarm wire, the alarm just sees the unlock wire activate and assumes that means it should disarm since you succeeded in unlocking the doors.
