Fabrication shop recommendations, bay area
NoCoastFocus
Aurora, CO
I need to have someone fab up an OTK steering for me. I can turn a wrench alright, but I don't have the ability to relocate the tb and weld everything up. I have the teraflex knuckle so that is the start. I really wanna make Sierra Fest but my steering needs some definite work first and foremost. Any recommendations would be great. Thanks in advance.
I have no facility right now but I do have a Tera knuckle.
I don't know what you're planning, but I have 1-ton GM TREs on my setup. I have the tie rod on top of the lower steering arm and the drag link on top of the high steer arm.
With 35x12.50 tires on 15x8s, I had to go to 3.5" BS to keep the drag link from rubbing on the sidewall of the passenger front tire. I think it'd be a little silly to buy the Tera and do all the fab wrok and not mount everything as high as possible.
I chose to get new wheels. You could do the same, if you have a similar setup as I had, or get a hub kit, or wheel spacers. It is possible that going to a bigger rim would help, but I don't know.
Hope that helps a little.
I have 15x8 with 4" bs. 32x11.50 and will be going no bigger than 33x12.50. Will I still have a problem? I didn't even think about the possible rubbing issues. I need to do some more research.
Letterman said:
West Coast Fab works in the San Jose/Campbell area does great work:
www.westcoastfabworks.com
I had West Coast Fabworks do some work for me. Custom fit HD t-case skid. I stole the idea from Jes and had Jan at WCF build it for me. Painted red for uber-gheyness.
I also have had some excellent work done at URF racing headquarters. These guys are to get ahold of though......
I also HIGHLY recommned DLD Fabworks and pizza parlor. All the beer and pizza you can consume is free while working with DLD.
Stay away from those guys, they'll drink all your beer!
DLD Fabworks Sucks! Only go there if you want parts to fall off! They did my Currie Stearing and I have had it fall off 2 times! :passgas:
That WCFW skid worked out good for your driving skills:
.!.:D.!.
