F.N.G.
- New Hampshire
Expedition Build: Yellow Jeep XJ
Now
Now
This is my XJ Expedition Project.
Then
That was my stock 2001 Jeep XJ...
Backstory:
This is my first real Jeep Project.
When I got the jeep the previous owner had installed a 3inch Suspension lift with 2inch spacers on the front and 2 inch Lift Shackles on the rear, sitting on 31inch tires.
He provided me with a picture of the vehicle stock, before the lift.
Everything else was stock, including the broken Sway Bar links.
It had a death wobble from hell, which I found out the hard way on the highway coming home after buying it.
Once we hit 40 mph and a bump, it shock extremely violently until it came to a complete stop.
The experience was like an 8.7 on the Richter Scale, inside a giant paint shaker, while trying to steer.
Any of you that have experienced an actual legit full fledged Death Wobble in all it's glory know what I'm talking about.
And I still had a 2 hour drive home from the sellers house...
So it was at this point that I decided to strip it down and start from scratch in regards to the steering and suspension components.
How it sat when purchased
Phase: 1
We worked on it slowly, a little bit each day.
I don't have a shop, so we worked in my driveway, weather permitting.
We diagnosed many of the causes to the "Death Wobble" symptoms through trial and error.
One of the by-products of lifting a Jeep Cherokee 5 inch with no modifications or upgrades to the stock steering or suspension.
We would be removing the present lift in favor of a long arm lift kit.
I also started prepping for some of the exterior mods we would be putting on as well.
Front/Rear Bumper Removal
Parts List
I started ordering parts, and one by one they began collecting on my front porch.
Once my porch was full, parts began collecting inside.
We were living in a Jeep Parts Shop, and kind of interesting.
Here is my part's list bellow
Suspension:
- RC 4.5 inch Long Arm Lift Kit:
- Lifted high flex coil springs
- Long arm Crossmember
- Adjustable upper control arms
- Adjustable lower control arms
- Transfer case skid plate
- Sway-bar quick disconnects
- Adjustable track bar
- Pitman arm
- Stainless steel braided brake lines
- Full Leaf Spring Packs
- Performance 2.2 Series Shocks)
- Rear Leaf Spring Shackles
Steering:
- New bearings,
- Moog upper and lower ball joints.
- Currie Currectlync Heavy Duty Tie Rod and Drag Link.
- Steering Box Brace.
- Upgraded Heavy Duty 2.2 Steering Stabilizer.
Brakes:
- New Rotors, Calipers and pads in front.
- Drums and shoes in rear
Tune Up:
- Air Filter
- Champion Copper Plugs, and wires.
- Oil change Mobile 1
- Change transmission fluid
- Coolant flush and fill
- New Thermostat
Drive Train:
- Slip Yolk Eliminator
- Custom Tom Woods Rear Driveshaft
Exterior:
- ARB Deluxe Bull Bar Front Bumper
- Warn 8000 Winch
- 2 IPF Spot Lights
- JCR HD Rear Bumper/Tire Carrier
- AJ's Super Rails Rock Slider
- Roof Slider
- JCR Gas Tank Skid Plate
- Bushwacker Flat Fender Flares
- Lower Rear Quarter plated on both sides
- Underneath re-coated
Wheels:
- 5 Cragar Soft 8 rims
- 5 Goodyear Wrangler Duratrac 33x12.5 inch tires
- Gorilla Chrome Lug and Lock set
Exhaust:
- Custom exhaust from the headers back
- Flowmaster Super 44 Muffler.
Miscellaneous:
- Fixed wiring on driver side door, passengers can now control power windows again.
- Fixed Rear Wiper.
- New Windshield Wipers
Parts:
Phase: 1 Complete
Everything installed and tested.
After a little tinkering it road great.
Great articulation, good clearance, and no vibration at all.
The only thing steering/Suspension related that is still OEM in the vehicle is the actual sway bar itself, everything else was removed and upgraded.
The roof sliders had a bend to it, so we flipped them in the meantime until we straighten them out.
They are actually supposed to come down just above the door to protect the sides.
We had help from a shop installing the Lift and some of the equipment because we simply ran out of time.
The weather was upon us and we were working out of my driveway. So we put the project on hold and finished it in the spring.
Rough Country 4.5 Inch Long Arm Lift Kit
2001 Jeep XJ after Phase: 1 of the Expedition Build
More to come...
