memasmuffn
- brackenridge
OK. i know this is in reference to a very old post...but a very valuable post!
My problem was with the difference between the 96-97-98 aw4...The vehicle I purchased was a 98 with a CEL code of P702 ...Hey no problem right? just a 02 sensor...WRONG! seems that someone replaced the 98 aw4 with a 96 aw4..After hours of research I stumbled across this great post and it made me understand what I was up against. --(transmission) 1996 1 output sensor(1pps reed),--- 97 change in wire harness, ---(vehicle) 1998 1 input and 1 output sensor(2 wire 4 pulse)both the same part # but different from the 96 and 97---- I live in an emissions area
and need that code gone...lawsoncl had posted a what if in a reply post about a 97 TCU fooling the ECM...I figured that someone had already spliced the harness connectors so why not give it a try...after finding wiring diagrams for both the 98 and 97 TCU, and finding that they were wired the exact same minus the input sensor on the 97, i sat out to find the 97 TCU...brought it home ,plugged it in,CEL code is gone,gone,gone!!!
arty:I am very,very happy because now I can continue my build without dropping another tranny into a perfectly running beast.
This fix also means that almost any aw4 can swap into almost any cherokee..Right?
